Order Ford 4400 Parts Online
4400 Power steering
C.W
08-13-2000 07:07:56
Hi.I have a 1965 Ford 4400 with loader and backhoe.The power steering feels hard at times and easy at others.I have three rib tires on the front.Oil resevoir is full and have installed a new filter.Any suggestions?I haven't pressure tested the pump yet.Need a new one maybe?Thanks.
Nathan(GA)
08-14-2000 19:59:13
 Re: 4400 Power steering in reply to C.W, 08-13-2000 07:07:56
C.W., I had a 4400 and now a 4500. I think there is a valve of some type on top of the steering cylinder in front. It actuates the cylinder. Check to see if there is any play in that linkage.
C.W
08-15-2000 17:45:06
 Re: Re: 4400 Power steering in reply to Nathan(GA), 08-14-2000 19:59:13
Thanks.After I did some reading I see there is a valve down there.I'm going to check the pressure on the pump first since that's easy to get at.Then I'll have to check that valve and cylinder.Thanks again.
