Order Ford 2000 Parts Online
2000 goes hunting
Jake
08-24-2000 10:23:01
I have a friend of mine that has a 2000. It is a three cylinder gas model. I guess it's a late 60's model. Anyway, the tractor runs fine, until you put it under load. It then "hunts" for the right rpm to run at. The tractor then bucks and jumps. We have overhauled the carb, put new points, cap and rotor, checked the vacuum advance and timing, and finally put a new governor spring on it. So, our current theory is that the governor cone has a groove in it. Does anyone have a similar problem or answer? Thanks.
