Order Ford NAA Parts Online
Jubilee @auction
Bill Mc
08-25-2000 19:09:21
I am going to look at a jubilee sunday. What problem areas should I look for.Thanks for the info in advance.
Bill Mc
the auction is over
08-27-2000 15:30:25
 Re: jubilee @auction in reply to Bill Mc, 08-25-2000 19:09:21
THE RUN DOWN. The tractor is all original never been repainted and one owner. Body in good shape only surface rust. Brakes good no oil leaks at the hubs. Started on the first key bump (no smoke)and purred like a kitten. One rear tire good the rest 30%. Rear end had a little "play" when the tire was pushed in toward the axle, both sides. The steering was tight. The tractor mechanically was sound but cosmetically poor. The auction price started at $1000 and ended at $3100. Too high for me! Ho one last thing a Dearborn buzz saw with belt and pulley went for $250
Bill Mc
2fords. thanks for the report
08-27-2000 17:12:43
 Re: Re: jubilee @auction in reply to the auction is over, 08-27-2000 15:30:25
Right on target for a good all-original Jubilee. The rough one's bring mid $2000 everyday here in the Cornbelt-Mi
Marc(MO)
08-26-2000 14:20:35
Check the block for cracks above the oil filter between the two core plugs. This is the likely place the block will crack if the coolant has been frozen. Look closely, it is easy to hide a crack with paint. Good luck.
Thanks for the replies
08-26-2000 13:26:54
I am going to do a little more research in the archives befor sunday, thanks again for the info
Bill Mc
Walt
08-26-2000 04:33:58
I would bring along a compression tester. Factory specs are about 125 psi. Look for at least around 100 psi per cylinder and not more than about 10 psi difference between cylinders. I would also hook up the tractor to an implement like a mower or brush hog and run it under load for a good 20 minutes to let it reach full operating temperature. I have seen alot of postings on this website about tractors that run great until they warm up and then they have problems when trying to work under load. Usually its a fuel flow or electrical problem.
Mike
08-26-2000 03:32:30
I bought a very nice looking Jubilee once and found a number of underlying problems, none of which were life threatening. (1) Check the side to side wobble of the tractor by pushing on the rear tires. A lot of slop there indicates worn hub/shaft splines. Not a hard repair job, but about $400 in parts if you replace the shafts, hubs, and seals. I tried to get away with only replacing the hubs at first. It was considerably better, but I eventually replaced the shafts when later replacing the brakes. (2) Excessive play in the front end spindle column is not expensive to repair, but it takes some time to fit new bushings. These are about $25 per side, including thrust bearings. (3) The battery box may have rotted out. Again not too expensive nor hard to swap.
I have never had any hydraulic problems with it, so I have nothing to offer there.
Good Luck,
MIke
bob
08-26-2000 02:08:09
the problems will be hydralic. it will probley have a vane pump. after it warms up try the lift if it works. its ok. they always work good cold.
