65-68 3cyl Gas Ford 4102
can we make it diesel
Beth Shaw
09-04-2000 17:20:44
My huband and I have recently purchased a "project" tractor. It is a Ford 4102 w/ a gas 3 cyl engine and a SOS transmission. We have the option on diesel engine off a similar year Ford 4000. It is a 3cyl diesel. Will this diesel fit easily in the tractor we have? How can we tell?? Any words of advice???
Larry 8N75381
09-05-2000 17:11:18
 Re: 65-68 3cyl Gas Ford 4102 - can we make it diesel in reply to Beth Shaw, 09-04-2000 17:20:44
Beth,
I would strongly suggest that you get both the service and parts manuals for the thousand series tractors. I got mine at the FNH dealer for about $70 each several years ago. Think they are also available from the board sponsors.
The service manual will be especially useful for all work on your "project". AND I would say it is a MUST since you have an SOS tranny. Trained SOS mechanics are getting to retirement stage.
A quick look at my parts manual shows that the SOS tranny case does NOT have any engine call out across the 2,3,4000 tractors. Also the rear cover on both the gas and diesel engines is the exact part number - this would be where the tranny bolts up to the engine. So I'd have to guess that there is no difference in the mechanical hookup. You might have some differences in the electrical and fuel areas.
I have ask, why do you want to change to diesel from gas? Is there something wrong with the gas engine that can't be fixed?
I picked up the whole back end of a 3000 that had been rolled for the differential lock. A 4000 engine would fit right up to it. :-) NNAaaah, I'd have to find all the sheet metal, etc. and I already have TOO many "Projects" lined up for my retirement.
HTH,
Larry
Beth Shaw
09-06-2000 18:51:04
 Re: Re: 65-68 3cyl Gas Ford 4102 - can we make it diesel in reply to Larry 8N75381, 09-05-2000 17:11:18
Larry, Thank you for the advice. We did purchase a general shop manual from Central tractor however we find it really lacking. It did help us to find the serial number and get started looking our project over. The manuals are on our shopping list. We have a dealer not far from us.
As far as engine problems with the gas engine - the previous owner did have trouble with the carborator but that is all that is suppose to be wrong with it although that can be enough. Once we do an inital assessmant of what the tractor needs my husband wants to tear the engine down and rebuild it. One of his friends from school offered him a diesel engine that has already been torn down. If it was not too much trouble to convert the tractor we prefer diesel over gas. It is just a personal preference. We both drive diesel trucks and almost all of the other equipment we have is diesel.
