Order Ford NAA Parts Online
1953 jubilee backfires through carb
Mark Stanfield
09-08-2000 19:45:03
I just had the head reworked with new seats, etc... The engine runs well at idle, but "coughs" once in a while (through the exhaust). Also, a backfire throught the carb when throttle is opened fast (sometimes does this). Is this a high speed carb adjustment or an ignition problem??
I've appreciated your help in the past.
Thanks.
Burrhead
09-08-2000 21:16:06
 Re: 1953 jubilee backfires through carb in reply to Mark Stanfield, 09-08-2000 19:45:03
It sounds more like the time is either set too high or the valves are adjusted too tight.
tuning
09-08-2000 21:27:16
 Re: Re: 1953 jubilee backfires through carb in reply to Burrhead, 09-08-2000 21:16:06
I went and looked the valves set at .015 hot, and the timing is 5 to 8 degrees BTC
