Order Ford 3000 Parts Online
3000 Select-O-Speed oil
Jim Hoadley
09-12-2000 06:58:22
What oil should I use for the Select-O-Speed transmission? Are there any tricks I should know before I change it? How frequently should I change it? In an earlier post someone suggested the bands require periodic adjustment. How often? Thanks for any help.
Jim
Bern
09-12-2000 12:32:54
 Re: 3000 Select-O-Speed oil in reply to Jim Hoadley, 09-12-2000 06:58:22
Depending on the year of your trans, the oil is drained through either a drain plug on the bottom of the case (later models) or through the suction screen at the bottom side of the case (earlier models). See a repair manual for a picture and the procedure for this.
The oil is filled through the level plug only. This prevents overfilling. Use NH oil #134D or its equivalent (tractor hydraulic fluid).
Not sure on the band adjustment. Probably every 3-500 hours or so. See the repair manual for the procedures and schedule.
Jim Hoadley
09-12-2000 14:09:50
 Re: Re: 3000 Select-O-Speed oil in reply to Bern, 09-12-2000 12:32:54
Bern,
I have a 1969 model. Would this model take the fluid you recommended?
Jim Hoadley
Bern
09-14-2000 22:10:57
 Re: Re: Re: 3000 Select-O-Speed oil in reply to Jim Hoadley, 09-12-2000 14:09:50
Yes, New Holland #134D or its equivalent (tractor hydraulic fluid that meets those Ford/NH specs).
