Order Ford 2000 Parts Online
62 2000 valve adjustment
Bill
09-17-2000 07:06:29
Is it nessecary to adjust the tappet clearance with the engine running or can I just do it with the engine at normal temp? Are there any shortcuts?
Mark
09-17-2000 19:44:38
 Re: 62 2000 valve adjustment in reply to Bill, 09-17-2000 07:06:29
Assuming you have the 134 c.i.d. gas, the book states that the engine should be at running temp, and when I last did mine, I did it running. The easiest way is with the sheetmetal off, as well as the gas tank, and use a service gas tank for fuel. this way it's much easier to work on the valves.
Pat R
09-17-2000 18:50:26
You should have the engine cold and not running in order to check/adjust valve lash! specs are given cold unless otherwise stated in service manual.
