Order Ford 600 Parts Online
600 info only
Ben
09-17-2000 17:49:36
I found a 600 that has been parked in a shed for about 10 yrs. Engine is not froze, tires are down. What is the HP, of this tractor, and dose it have full time 3 point, if I step on the clutch will the 3 point still raise? I have never had a ford tractor, but I might soon have one.
mech
09-19-2000 08:08:17
 Re: 600 info only in reply to Ben, 09-17-2000 17:49:36
The 600 is anywheres from 32-37 hp the hydraulic holds all the time.I own a ford 8n ,NAA,640 and 861 the 640 is probably the most reliable and my favorit tractor of the bunch it was a great improvment from the NAA and it does not eat as much gas as the 861.
RWK in WI
09-17-2000 19:45:42
30 /35 Hp. Live Hydraulics, 4 speed & some 5 speeds are transmission PTO, some 5 speeds are Live PTO. SOS transmissions are usually best avoided. Good Tractors. I have a 640 , a 860 and a 960. I like the 640 the best.
happy tractoring.
rod
09-17-2000 18:42:33
Try this site. You will need the serial numbers, located under the starter Link
>Link
