3PT vibrates and will not hold
Old George
10-05-2000 15:53:17
Gentleman,
1983 1510 lift oscillates unless it is resting on ground or moving up or down. It also leaks down almost as soon as I shut down the engine. Does this sound like a leaking lift piston/ring or is there something else I can try before pulling the lift cover? Fluid is fresh, did not seem to have any effect. Thanks in advance.
Pat R.
10-05-2000 18:28:39
 Re: 3PT vibrates and will not hold in reply to Old George, 10-05-2000 15:53:17
Sounds like your on the right path! I would pull the lift cover and check the piston seals and also the condition of the cylinder.
