3pt. hitch question.
PaulCtOH
10-17-2000 12:09:38
On my 3000, there is a little flat lever under the seat , on the right side. What does that do? Thanks , Paul.
Drew / Millington, MI
10-19-2000 04:11:17
 Re: 3pt. hitch question. in reply to PaulCtOH, 10-17-2000 12:09:38
Here is a posting of mine, from about 4 months ago, I think that it answers your question.
Sounds like your hitch is in "draft mode". (1) Locate the "mode control lever". It is near the "quadrant" (the thing that holds the "touch control" lever) and is just about under the seat. It is located near the top of the hydraulic housing (on the right side) and is about 3 inches long. On your tractor, it should be pointing down (perpendicular to the ground). Rotate it into the "position control" mode by moving it CCW (it sould be parallel to the ground now). (2) Basically, in "position control" mode, the position of the touch control lever dicates the position of the 3-point hitch. In "draft control" mode, the touch control lever is used to postion the implement on the hitch relative to the ground. Then the feedback from the implement (to the 3-point hydraulics) causes the 3-point to move such that the implement remains at constant depth relative to the position of the tractor to the ground. (Look at the top hitch point at the housing and see the rod that is surrounded by the large coil spring -- that is the feedback "circuit") You would use this mode for a plow, but not for a blade (although I have). Also, as you know, in "draft mode" the 3-point is very sensitive to the touch control. (3) There are several discussions of this mehcanism and modes of operation on this forum.
PaulCtOH
10-19-2000 06:06:10
 Re: Re: 3pt. hitch question. in reply to Drew / Millington, MI, 10-19-2000 04:11:17
My lever points forward or vertical. The big spring is enclosed on mine. I appreciate the helpful posts here. I appreciate the time it takes to answer inquiries.
Kermit
10-18-2000 23:00:19
I agree with Chuck. It sounds like your talking about the lever that engages the draft control. I used it on my 3000 for plowing.
PaulCtOH
10-19-2000 02:16:51
 Re: Re: 3pt. hitch question. in reply to Kermit, 10-18-2000 23:00:19
Thanks for posting. The 3000 I'm fixing up is a low center of gravity tractor. I have a steep pasture. I used to mow it with a dozer years ago.
llexort
10-18-2000 13:06:54
Thats how you flush it.
PaulCtOH
10-18-2000 15:44:01
 Re: Re: 3pt. hitch question. in reply to llexort, 10-18-2000 13:06:54
I might need to use that lever in case this 3pt. assy. that I'm putting on doesn't work!
Chuck
10-17-2000 14:08:31
That lever switches operation from position control (lift arms move and hold position corresponding to control position) to Draft control (varies depth of tool engagement for constant drag force)
PaulCtOH
10-17-2000 14:37:32
 Re: Re: 3pt. hitch question. in reply to Chuck, 10-17-2000 14:08:31
Thank you for taking time to post. Since I'll be using a rotary mower, I won't need the draft control feature. I just got finished transferring the 3pt. assy. from a "junk" tractor to the one I'm going to use.
The tubes from the oil supply to the pump are on order. I hope the 3pt. assy. works.
