Order Ford 2000 Parts Online
2000 Lift
Gary
10-23-2000 10:10:55
I have an early Ford 2000 (Red) and my 3-pt. lift won't come up all the way. I've been told that there maybe some worn out pins inside of the lift area were the lift arms are connected. I can't find this in my service manual. Has anybody heard of this or am I being told a fairy tale?
Pat R.
10-25-2000 19:04:44
 Re: 2000 Lift in reply to Gary, 10-23-2000 10:10:55
It could be a valid statement? You will have to take off the lift cover and check the pin that rides on a cam this could be worn. Or the linkage could be out of adjustment?
If your trying to get away with an I&T manual,good luck! I would prefer a Ford service manual. If you don't know what you doing with the adjustments you may as well take it to a local New Holland dealer and let them fix it!
