Order Ford NAA Parts Online
NAA VANE PUMP HELP
BOB
10-25-2000 02:45:01
ive been watching different hyd problems for a year. (here is my story). when i bought my 54 naa everything worked except pump.changed all suction and discharge o-rings, then it would work 30 min and quit. i was afraid if i took pump apart i would never get it back together. i lived with it,then one morning i went out for my 30 minute work, noticed gas leaking out of tank right on pump.wiped it off. started up pulled lever up i couldnt believe how fast it went up. my guess is the gas swelled out the large o-rings inside.took it apart changed all o-rings.(easy to do) has worked perfect since. also fixed gas leak maybe this will help some of you
Joe
10-25-2000 16:48:01
 Re: NAA VANE PUMP HELP in reply to BOB, 10-25-2000 02:45:01
Thanks Bob Your right, it is easy to do and people should not be afraid to try rebuilding their pump. The o-rings make a world of difference.
