Order Ford 601 Parts Online
601 Series
albe
10-30-2000 10:48:11
My "new" tractor has a "600" emblem on the front. The markings at rear of starter on the trans. says a 621 and the serial number indicates a late 1961 model. It has a 3-point hitch, PTO and 4-speed transmission. It has a fuel gage (not working), an oil pressure gage, an empty hole, no hole for a proofmeter and no headlights. The engine appears to be the 134 CID gasoline engine. What exactly do I have? Thanks Albe
Jim.Ut
10-30-2000 15:15:01
 Re: 601 Series in reply to albe, 10-30-2000 10:48:11
Could be anything. The only thing you can be sure of is that you have a 4 speed transmission out of a 621. What color is it and does it appear to be the original paint? Does it have a 3ph and a pto? If I remember the info on the Vintage Ford Tractor Resource correctly, a 621 would have neither of these things. If yours does, then i would lean toward you having possibly a 600 with a boneyard transmission from a 621. The front emblem really proves nothing as they are easily swapped, too. Check the link for more info.
albe
10-30-2000 17:21:07
 Re: Re: 601 Series in reply to Jim.Ut, 10-30-2000 15:15:01
Thanks Jim, Looks like the hood was painted grey(long time ago) but under grey is red. It does have a 3ph and PTO. Also, fuel tank holds about 13-14 gallon which could make it a 601 series? It does have holes where headlights should be but no hole for a switch. Runs good and strong so that's O.K.. I would just like to know since some tune-up specs are different between a 600 and 601. Thanks again.
2fordsmike
10-31-2000 09:08:24
 Re: Re: Re: 601 Series in reply to albe, 10-30-2000 17:21:07
Hmmm: Red hood would indicate 601 series. PT0 was an option on 621. 3 pt was not supposed to be a part of the package, but I've seen one like this before and it also had 3-point. I'm guessing these were sold as bid tractors to school, town or state, or as a price leader to farmers. Until you know more, I suggest you consider it a 621. And, you're lucky to get one! Mike-
