Order Ford 4000 Parts Online
1963 4000 diesel engine identification
David
11-01-2000 15:34:10
144 or 172 cid casting #'s on engine CONN-6015J and EAF on timing cover serial #'s on tractor are corroded away
Tony Jacobs
11-01-2000 20:10:20
 Re: 1963 4000 diesel engine identification in reply to David, 11-01-2000 15:34:10
David , Your engine is a 172 cid Ford diesel , more than likely the original one that came from the factory . Thanks Tony Jacobs
walt(try again)
11-01-2000 18:53:43
try again..
http://members.aol.com/naa60512/naa.htm
walt
11-01-2000 18:51:43
try this site..
a brown
02-24-2003 12:12:00
 Re: Re: 1963 4000 diesel engine identification in reply to walt, 11-01-2000 18:51:43
I also am looking for info on an engine with CONN 6015J casted into the right side on the block. This engine is not a diesel but a gas engine on propane in a Chipper.I would apreciate any info.
Thanks AB
