4000 3cyl D
knock and flutter
Jeff
11-03-2000 13:43:36
Some time back I asked this question and didnt follow up on the replies. I have a 3cyl Deisel that has terrible deisel knock (louder than normal) it also has a "flutter" under high idle, no load. I was told the flutter is common with certian types of pumps on these models it has the rotary style pump (not the in-line) I have had allot of tractors over the years and I have never had a deisel that knocks as loud as this one. Oil pressure is good and no sings of excessive engine wear. Could the two be related?? Injectors or timing off?? Someone said this is common for the 4000 to be so loud and just put it to work and stop worrying??
any comments will be appreciated
Jeff
jeff
11-03-2000 21:00:04
 Re: 4000 3cyl D - knock and flutter in reply to Jeff, 11-03-2000 13:43:36
Mine knocks too....55 pounds oil pressure uses no oil.....I say run it! jeff
