Order Ford 5000 Parts Online
5000 Ford Diesal
Mike
11-06-2000 18:05:12
I want to convert this tractor to a delco style internal regulated alternator will it work and would anyone know the wiring diagram as the old regulator has five or six wires coming off of it any help appreciated.
Michael (Sweden)
11-08-2000 01:20:07
 Re: 5000 Ford Diesal in reply to Mike, 11-06-2000 18:05:12
I think that my 5000 is converted to what you are after.
It used to have a generator with a separate regulator.
I think that it is a small problem for you to connect the new alternator.
What connections do you have on the new alternator?
If you have like this there is no problem:
D+
B+
B-
D+ is the connection to the warning-lamp (just follow the wire from the lamp) B+ is like it says Battery positive (+)
B- battery negativ (-)
And if you have a W connection you could connect a electronic rpm-meter.
The old regulator and wiring from the generator will not be in use.
Good luck
