1910 Front End 4x4 Differential Problem, drive rem
Artie
09-20-2004 06:50:42
Well I narrowed the problem down to the front differential assembly. My question is now. To remove the drive train (which comes from the rear to the front box, how do you go about it? I dont want to ruin anything when removing it. I took the 4 bolts out that hold the shaft cover to the differential.
Should I drop the differential then remove the drive shaft or vice versa?
