Larry, Thanks for your effort in researching #'s. I'll check w/ the local FNH to see if they still stock them. I've just bought this '71 2000 diesel and am in the process of correcting fudged repairs, mis-wired cold start aid, one rear tire filled w/ calcium chloride (leaking from stem), tach/proof not working due to an incorrect generator, steering column upper oil seal leaking. Well, generally all the usual projects which come with a used treasure. You know the drill. That being said, I have been looking for exactly this model for a number of years. I found this one located within an hour of here, so I jumped. The only tests I did before handing over the check were: cold starting engine with air temp at 34F and load testing the hydraulic lift system. Those are the BIG money areas. Engine fired up eagerly and hydraulics were fine. So here I am now, looking for obscure pieces of sheet metal. Jim.
