4k injection pump leak
williy
11-10-2000 16:05:53
My 4000 has a fuel leak at the throtle shaft. does anyone know if they make a seal kit for the injection pump.
Thanks,
williy
Roy
11-12-2000 18:36:44
 Re: 4k injection pump leak in reply to williy, 11-10-2000 16:05:53
Williy
Had the same problem on my 5000. Im no injector pump mechanic so I had one come to my barn to do the job. Cost me $100.
Bern
11-12-2000 12:43:42
Not a kit acually, however, there are two o-rings on this shaft that need to be replaced. Get yourself 4 o-rings (two also for the shutoff shaft) and the cover gasket. That should be all you need for parts. Be certain that the pump is perfectly clean before you remove the cover. That pump will not tolerate any water or dirt!
williy
11-12-2000 17:10:19
 Re: Re: 4k injection pump leak in reply to Bern, 11-12-2000 12:43:42
Bern Can I purchase these o-rings at my local N.H. dealer or do you know source? My local dealer said they would gladley sell my a pump for $*$*$600+. I would rather push my trator then pay $600+ for .20c worth of seals.
Regards,
Williy
Bern
11-12-2000 17:27:48
 Re: Re: Re: 4k injection pump leak in reply to williy, 11-12-2000 17:10:19
Yes, they can get them. I'm assuming you have the CAV rotary style injection pump by the way (injection lines come out of the pump at various angles).
The gasket part # is C5NE 9C568 A. The o-ring PN is 49886, according to the info I have here. Give your dealer the part# for the gasket, have him look up the application on a 4000, and he should be able to come up with an exploded view of the pump for you. To make amends, make him print you a copy of it so you can see what all is inside that thing.
