Order Ford 800 Parts Online
Cost guestimate for clutch replacement on 800
Greg Croasdill
11-12-2000 05:57:35
My tractor Ford 800 just stopped working today. I need the thing to do a little more work around here before winter hits for real, so I'm looking for "sage advice"(tm).
I'm about 99% sure it's the clutch (press the clutch, put it in gear, let out the clutch and tractor moves slowly or not at all). I'm not much of an auto-repair kind of guy, I'll do pugs, oil and work on the starter, but pulling the beast in half to get at the clutch sounds like a little too much for me ;-)
I don't have much time so my best option seems to be to take it to the local ford/new holland shop. But, don't have a clue what a clutch relacement should cost - so I won't know how far I'm being taken to the cleaners ;-) I could have someone come here, but the same problem applies.
So I take it to the shop? try to find someone to come to the farm and work on it? It's not very rural round here anymore, so I don't know if I can find a tractor mechanic to just come on over.
Thanks for any help and advice.
Greg C
gregc@annarboralpacas.com
ann arbor, mi 48108
BTW- If one of you is in my area and wants to come help me fix this, I'd be willing to pay limited travel and good wage.
Stephen
11-23-2000 16:19:48
 Re: Cost guestimate for clutch replacement on 800 in reply to Greg Croasdill, 11-12-2000 05:57:35
If this is a single stage clutch I generally get $325.00 for the complete job. R&R the clutch new pressure plater, new disc, throw out bearing, pilot bearing and surface the FLYWHELL. Good Luck Stephen
Drew / Millington, MI
11-12-2000 18:17:09
Based on work that I had done last year, I would guess that in A-squared that a clutch at the NH dealer will run about $700 to $950, depending on which type of clutch you have.
(In my mind, based on my job, etc, worth every penny of it!)
Jim.UT
11-12-2000 06:07:36
Greg, you don't mention which model of 800 you have. If it's an 860 with the two stage clutch, you are looking at parts cost double or more of a standard clutch found in models 820,830,840,850. If you're not sure which you have, check this site and the numbers stamped on the transmission on the left side.
