My first Ford
Ben SO. TEX
11-12-2000 11:17:03
About 6 Wk ago I got my first 640, Now I have some Questions. 1st How do i get the fuel tank clean? 2nd, the head gasket leaks alittle water when I first crank it but stops leaking after it run for about 5 min, What is the proper head bolt psi# ? I am going to replace the head gasket. 3rd What should the exhaust and intake valve Tappets clearence be? THANKS BEN
Stephen
11-23-2000 16:12:29
 Re: My first Ford in reply to Ben SO. TEX, 11-12-2000 11:17:03
The head torque is 65-70 lbs, valve clearance is .015 straight across. As for the gas tank it is inevitable to remove it and seal it properly. Good Luck Stephen
tom
11-13-2000 04:33:28
I've heard some people put marbles in the tank and shake it around. When you put the tank back, make sure it is bolted tight - no vibration.
All valves are .015" hot.
Don't know head bolt torque.
Good luck.
Jim.UT
11-12-2000 14:43:33
Sounds like you don't have a manual. Should get one. The reprint Ford manual is generally considered better than the I&T version for this tractor. I don't have mine handy and I'm no mechanic, but some of your questions can be answered on the linked site. Click on the "Engine" and "Torque Specs" buttons. Have fun with it.
Ben SO .TEX
11-13-2000 15:08:29
 Re: Re: My first Ford in reply to Jim.UT, 11-12-2000 14:43:33
Thanks Jim. That is a great site for some of the info I needed. I am going to try the marble trick also that Tom wrote about.
John
11-19-2000 10:10:25
 Re: Re: Re: My first Ford in reply to Ben SO .TEX, 11-13-2000 15:08:29
My 641 had rust in the gas tank so I went to all the work of taking off the gas tank and used shingle nails and mineral spirits to slosh around to clean it.It did not work all that well. I wish I would have took it in and had it sealed.Just my opinion. Good luck
Ben So Tex
11-19-2000 17:35:27
 Re: Re: Re: Re: My first Ford in reply to John, 11-19-2000 10:10:25
Thank John I did not do the marble thing, thought I might have trouble getting them all out, I put some painter tinner in the tank and that seems to be doing the trick,and I do have the tank off so I can shake it around.
