4-speed trans Main shaft Bearing
Matthew
11-13-2000 04:44:05
Split my jubilee this past weekend to replace oil seal and main shaft bearing. The whole job went well. I have the main shaft out and want to replace the bearing and oil seal. Is the main bearing pressed onto the shaft? Mine seems to not want to move. I haven't tried to hard to remove the bearing untill I know if it is pressed on the shaft or should it slide off?
Matthew
Bern
11-13-2000 12:31:44
 Re: 4-speed trans Main shaft Bearing in reply to Matthew, 11-13-2000 04:44:05
Most bearings in most transmissions are a press fit, usually requiring the use of either a puller and/or a press for removal. If a bearing does slide off by hand, look for damage in the bearing mating area of the shaft.
