621/rear blade
albe
11-26-2000 15:59:22
Thanks to all of your help. The tractor is running quite well now. I was able to adjust the top link to get more "bite" with the blade. I did notice that when I have the control in the full "up" position, the bottom of the blade is only about 2 inches off the ground. When I shred, the shredder is about a foot from the ground in the full "up" position. Do these heights sound correct? Thanks. Albe
Drew / Millington, MI
11-27-2000 18:37:09
 Re: 621/rear blade in reply to albe, 11-26-2000 15:59:22
The 7 foot back blade on my 661 lifts about 2 feet (maybe more) off the ground when the touch control lever is full-up. Are you in touch control mode or in draft control mode?
albe
11-27-2000 18:51:49
 Re: Re: 621/rear blade in reply to Drew / Millington, MI, 11-27-2000 18:37:09
Drew, I'm in "position" mode. I have not tried draft control.
albe
11-27-2000 18:50:34
Drew, I'm in position mode. I have not tried draft control.
