Copper wire core plug wires
bob pomykala
01-09-1999 08:57:41
Do I need to use copper wire core plug wires for my ford 600 ? Is there a difference in voltage carried, resistance, etc. ? thanks! bob
zane
01-09-1999 17:59:22
 Re: copper wire core plug wires in reply to bob pomykala, 01-09-1999 08:57:41
You don't "need" copper core plug (or coil) wires if your others are working OK. The advantage of copper (or other metal) is that they are more dependable. Graphite and/or resistance cores are prone to separate and cause missing, but they interfere less with your neighbor's radio and TV! (The amount of electric current carried by a plug wire is so miniscule that resistance is relatively unimportant.)
Skillet Licker
01-12-1999 14:17:55
 Re: Re: copper wire core plug wires in reply to zane, 01-09-1999 17:59:22
>>>(The amount of electric current carried by a plug wire is so miniscule that resistance is relatively unimportant.) <<<<
Yeah...Tell him that AFTER he gets the crappola "bit" by the "miniscule" amount of current coursing thru the plugwires while the tractor is running....Besides..if the current was so miniscule, A LOWER resistance would improve the current flow..
skillet
zane
01-12-1999 18:12:46
 Re: Re: Re: copper wire core plug wires in reply to Skillet Licker, 01-12-1999 14:17:55
The (yes, miniscule)current's not bitin' you. The punch comes mostly from the voltage. Like when you walk across a dry carpet in cold weather and touch a metal doorknob. The ignition coil increases the voltage from the battery to several thousand volts (15-25,000?), but decreases the amperage (current) by the same factor.
