172 oil pressure problem solved
snitkawl
12-13-2000 16:12:30
After trying everything I could think of and all your suggestions, I called the FNH service dept and had them fax me a picture of the oiling system. It says right in there that oil holes in the camshaft have to be lined up with holes in the block in order for oil to get to the overhead. With each revolution of the cam a squirt of oil goes to the rocker arm shaft. Problem was, I wasn`t turning the engine and the holes weren`t aligned, so no oil. When I lined them up, presto!, there was the oil. Only burned about 10 hours solving that beast. Oh well, tuition in the school of experience. Now on to sheet metal work.
Thanks to all for your suggestions.
Bill Seifert
12-16-2000 19:41:10
 Re: 172 oil pressure problem solved in reply to snitkawl, 12-13-2000 16:12:30
Yes I'm greatful never heard of that before. All eng. I overhauled never worked like that. I'm also an unwilling student of the school of "hard knocks". The tuition is darn high sometimes.
Drew / Millington, MI
12-14-2000 17:33:13
Snitkawl - Your adventures are always interesting. Thanks for the info.
Regards.
- Drew
Jim K
12-13-2000 17:46:57
Yes but think of all the people out here that don't have to go through what you did now that you've found the problem. I'm greatfull! anyone else?
Jim.UT
12-13-2000 20:50:40
 Re: Re: 172 oil pressure problem solved in reply to Jim K, 12-13-2000 17:46:57
Yep, I'm gratefull, too, but I'm not paying him any tuition! Thanks for the followup.
