Height of 3 Pt. Lift
Allan
12-27-2000 12:49:12
How high should the 3 pt. raise above the ground on a Ford 841? Measured to the hitching points. Or since that question is tractor height above the ground dependent, what is the vertical range of the 3 pt. hitch from lowest to highest point above the ground?
Bern
12-27-2000 22:19:05
 Re: Height of 3 Pt. Lift in reply to Allan, 12-27-2000 12:49:12
Best way to tell is to lift the arms as far as they will go up without anything attached. Then grab the arms and force them up more manually. They should go up a little bit more, maybe 2 or 3 inches or so as measured at the end of the links.
