Order Ford 4000 Parts Online
4000 4X4 (4) CYL INFO
TOMC
12-27-2000 16:16:13
I have recently acquired a 1963 gas 4000 indust with 4 wheel drive. I'm looking for a manual or copies of the transmission illustration of how the front gear box is powered. I want to see if I can add a rear pto(probably live all the time)since the front gearbox is mounted where the pto shift lever normally is. Any and all help will be appriciated!
Tony Jacobs
12-28-2000 10:20:41
 Re: 4000 4X4 (4) CYL INFO in reply to TOMC, 12-27-2000 16:16:13
Hi Tom , Your tractor has an Elenco Front axle on it , I have all the info you may need for the tractor, Do you know what the serial number is ? I assume you mean front axle , since there is no gear box on the tractor . The transfer case for the front axle is mounted on the side of the rear axle housing where the pto cover used to be . Where are you located ? I live in Mass. Thanks Tony Jacobs
