First time tractor owner !!!!!
Allen C.
12-28-2000 08:57:26
I receintly purchased a 1962 ford 801 powermaster
fully restored for around 4500.00. So far the tractor has been a great asset, however I don't know a whole lot about it. I am curious about the amount of horse power it has and any other helpful hints you may have.
Thanks,I look forward to your comments. Allen
Tom Fischer
12-29-2000 06:16:21
 Re: first time tractor owner !!!!! in reply to Allen C., 12-28-2000 08:57:26
That's a nice tractor. I have a 641. The 641 has 134 CID motor rather than the 172 CID motor that you have.
If possible, store it in a shed. Also, I always leave the hood open on mine when not running. That way the wild cats keep the mice company :)
Good luck.
Steve
12-28-2000 19:13:04
Allen, I dont know how to post a link...But go to a search engine and type in The Vintage Ford Tractor Resource and it will take you to a great site and you can find out all you need to know about your tractor. Happy Tractoring!!
tlak
01-01-2001 05:11:19
 Re: Re: first time tractor owner !!!!! in reply to Steve, 12-28-2000 19:13:04
If you interested. To post a link right click on the address (http://)at the top of the page then click copy. Go to Post A Followup and at the bottom is Optional Link URL: right click again and paste. Then go to Link Title and type in whatever you want ot call it.
TWW
12-28-2000 12:23:14
Sounds like a nice tractor. The 800-801 series is about 45hp. As for hints, remember to turn off the gas (valve on bottom of tank) so that if your carb float has a problem, you won't fill the engine with gas. Those gravity fed systems can be a disaster if there is a problem in the carb. Also, mine will flood out if you have the choke on more than just a second or two while starting. Finally, note that there are several places for fluids. The engine, transmission, hydraulics, and rear end, all have their own separate cavities. GET A MANUAL! The IT Manual is used by many and is available at most farm type stores. Have fun...
RWK in WI
12-28-2000 19:52:57
 Re: Re: first time tractor owner !!!!! in reply to TWW, 12-28-2000 12:23:14
Just remember that on the 800 series you need to shut off the fuel valve with a screwdriver as there isn't room for a valve you can turn with yur fingers. It's a pain.
Jim.UT
12-28-2000 19:11:16
I prefer the reprint of the factory Ford manual to the I&T...I have both manuals and the Ford reprint just has more info. I got mine from Ebay for about $15 ($18 with postage). Just type in "ford tractor manual" in the ebay search box and you'll find lots of them. As for more info on the tractor I recommend the Vintage Ford Tractor Resource. Enjoy it!
Hilltopper
12-28-2000 14:22:51
TWW is correct. Spend some money and buy a manual. Also, you may not know how far the restoration went, so I would replace all fluids unless you know the tractor was completely dis-assembled. Have fun and don't roll it over!:-)
