1973 County 1004
Transmission Noise
Scooby
12-31-2000 09:04:47
The transmission (Ford 5000) has a noise sounds like its connected to the PTO/Hyd.Pump driveline. If I use the spool valves (load the system) the rattle/whine stops.
I think it is either the top shaft or pump idler gear.
If so, how big a job is it to do?
RickB.
12-31-2000 12:25:13
 Re: 1973 County 1004 - Transmission Noise in reply to Scooby, 12-31-2000 09:04:47
The pump idler gear is a rear split. The top shaft requires a double split. Does the noise stop when the clutch is disengaged? If not, rule out the transmission top shaft, most likely. You could pull the pump & have a look.
Scooby
12-31-2000 12:45:44
 Re: Re: 1973 County 1004 - Transmission Noise in reply to RickB., 12-31-2000 12:25:13
The noise is constant, no matter where the clutch pedal is, but surely the shaft turns all the time?
RickB.
01-01-2001 06:03:35
 Re: Re: Re: 1973 County 1004 - Transmission Noise in reply to Scooby, 12-31-2000 12:45:44
The Primary PTO shaft turns all the time, driven by a drive hub bolted to the crankshaft. This shaft drives the inner hub of the PTO clutch, which also has a gear that drives the hyd pump idler gear. The transmission top shaft does not turn unless the clutch is engaged, and has nothing to do with the hyd/PTO drive train, other than surrounding it (the top shaft is hollow).
