Order Ford 801 Parts Online
Need help with casting numbers for 801
Barney
12-31-2000 12:56:57
Here is the casting # from the block, EAE6015. On the side where the oil filter cannister is, the number <22> is under the cannister. The head's casting number is EAE6085E. I am needing a block for my 801 diesel. Is this block the right one, or do I go ahead and build this gasoline engine and use it instead? If anyone can tell me what this block is, and when it was made, I'll be very thankful. Barney
Tony Jacobs
12-31-2000 14:48:01
 Re: Need help with casting numbers for 801 in reply to Barney, 12-31-2000 12:56:57
Hi Barney,You have a 1953-1957 134 c.i.d. gas engine , the casting date is on the left front corner just above the oil pan rail . Thanks Tony Jacobs
Barney
12-31-2000 15:47:47
 Re: Re: Need help with casting numbers for 801 in reply to Tony Jacobs , 12-31-2000 14:48:01
Thanks for the information, Tony. I can still use it in the 640,and that's good,I just wanted to get the 801D going. Barney
