Dexta questions for new guy
Bill McDaniel
01-02-2001 08:16:03
Hi, I'm a JD guy, but just fell for a cheap Super Dexta and have a couple of questions.
1. The operators manual shows a fuel primer button incorporated with the fuel cut off (tap) on the left side of tractor under the fuel tank. Mine has no trace of the button (just a shut off fitting) but I found the nozzle and brass fitting on the manifold above the heater. It has been capped off by cutting the tubing short and bending it closed! Do you have a reason why this was done? Did we blow up too many engines?
2. The operators manual and ITT manual claims that the serial number is on the left side of the tractor and stamped on the clutch housing flange. This site lists serial numbers as 9A-xxx
through 9D-xxx, but the IT manual claims that the serial number is prefaced by the model number in which case I think its 957E. There are several casting numbers on the right hand side of the clutch housing, but on the left side, I can make out nothing. Can someone help me out on this one and not call me an idiot? Everything I see says that this is really a Super Dexta because it has a mechanical and not pneumatic fuel controller and because it says 'super dexta' on the hood.
Also, would you recommend lubes for the following warm climate (San Antonio). My pages 42 to 64 of the operators manual are unreadable (would be glad to pay for some reproduced pages if you would) 1. Trans (book says SAE30?) 2. Rear axle (can't read what the book says, but would suspect SAE30 since the hydraulics use the same oil. 3. Steering box (mine is currently packed with heavy grease as are most John Deere because people got tired of seeing them leak. 4. Engine 5. Fuel pump
I thank you for your time in advance.
Bill
Bill McDaniel
01-02-2001 17:36:00
 Re: Dexta questions for new guy in reply to Bill McDaniel, 01-02-2001 08:16:03
Thank you for the advice JW. I thought I was in the right place. I'll move it to the Fordson page.
Bill
jw
01-02-2001 12:12:05
bill you will probaly get more response on the fordson page Jw
