641 with a Zenith carb question?
BigJ
01-02-2001 14:43:24
Purchased a 641 WorkMaster last week and it seemed to be missing.I pulled the choke lever out about a half an inch and it runs good.I am guessing it is needing more gas but where do I look for a blockage first?I know the fuel flow is good to the carb but is there a fuel nozzel that stops up on those that can be cleaned easily?I have read other posts that said to throw away that Zenith and get a Marvel-Shiebler carb,is this the thing to do?I am new to this kind of tractor so I need this advice.Thanks,Jack(TN).
rod in NS
01-05-2001 07:37:53
 Re: 641 with a Zenith carb question? in reply to BigJ, 01-02-2001 14:43:24
I have a Zenith carb on TEA 20 Ferguson. You may have an air leak around carb gasket or dirt in bowl you can pull the plugs to see what they look like if they are black you are getting too much fuel. Lots of things can make it miss. If champion plugs I would replace them first they don't seem to be to good for old tractors. Also if looking for a kit try>Link
regards
rod in NS
rod
01-02-2001 17:30:42
Like most comments here, Get yourself a IT manual. Sounds more like just a carb adjustment. Try this link till you get a manual.
Link
