1710 Wheel Tire size?
Ray T.
01-03-2001 11:56:34
Would like to know the standard size for 1710
rear wheels and tires.Tractor currently has
turf tires on it.With 11wx16 rims.
I want the regular tractor tires,for construction
for it.
Any suggestions would be appreciated.Where do I start looking?
Ray in california,Thanks!
Gaetan
01-18-2001 03:59:00
 Re: 1710 Wheel Tire size? in reply to Ray T., 01-03-2001 11:56:34
Ray,
Correction for the tractor I tell you it was 7710 but it was a 1710 sorry about the mistake.
Gaetan
Gaetan
01-18-2001 03:53:10
Ray,
Tractor number #BB35200 - Model FC415L - The wheel has 4 spoke with 2 bolt on each spoke.
Rear tire 18.4-34 overall width of the rim outside
to outside 181/2 inch.
Front tire 14.6-24 overall width of the rim outside to outside 131/2 inch. It is a 7710 serie 2 the guy bought it brand new and tell me that the size of the tire is original. I stop by yesterday and I mesure them myself. He couldn't tell me what kind of thermostat that he had in it.
But he never had overheat problem.
gaetan soucy
01-04-2001 15:40:49
rim 17 inches
tire 18.4-34
gaetan
01-04-2001 15:38:12
rim 17 inches
tire 18.4-34
Ray
01-05-2001 17:49:26
 Re: Re: 1710 Wheel Tire size? in reply to gaetan, 01-04-2001 15:38:12
Hey gaetan! Thanks for the response!Do you own
a 1710?If so what size tires are on the front?
Is it 4 wheel drive?
I understand that to keep from problems with the
front end, the front and rear tires and wheels
need to be a certain size for each respective set.
What type of thermostat do you run?
Thanks again..... ..... ..... ..... ....Ray
gaetan
01-16-2001 13:11:11
 Re: Re: Re: 1710 Wheel Tire size? in reply to Ray, 01-05-2001 17:49:26
iam not trying to be funny .my friend has one that he buy brain new and still has it.tomorro i stop by and mesure the rim front and back and tell you the size of the tire also
RickB.
01-05-2001 18:03:33
Ray, that guy is either trying to be funny, or knows nothing about your 1710. The tire size he mentioned is for large farm tractor rears. The standard tire size for your rears is 11.2 X 24. Not sure about the front, something like 7.00 X 16, but verify that for MFD. The problem is the bolt circle, hub pilot and lug hardware is metric and few if any aftermarket sources exist for rims.
