Order Ford 600 Parts Online
600 Ford
Bill C
09-24-2004 08:37:26
Engine is missing. If I pull a plug wire off of number 1 or 4 while it is idling and let it arc to the plug it kicks in and runs smooth on all 4. As soon as I snap it back on it starts missing again. I"ve changed plugs, points, condensor, rotor, distributor cap, and wires. Any suggestions would be welcome.
Stan Proffer
10-25-2004 18:43:32
 Re: 600 Ford in reply to Bill C, 09-24-2004 08:37:26
My dad said you may have the wrong plugs (too cold) the coil is bad, or the points are not set right? Most likely the coil.
jc
09-25-2004 07:31:22
Sounds like bad wires. When they are in place the spark arcs off before reaching the plug. You are holding the wire it is away form the outside arc point.
