Order Ford 4000 Parts Online
1968 Ford 4000 Diesel
Roger Marcus
01-14-2001 10:00:59
I am looking at a 1968 4000 to buy. The pto will not go in gear when the engine is running but operates fine if you shut engine off and put pto in gear before you crank. I am not a tractor expert and wonder if this is a major problem. How much should I pay for a tractor like this. Thanks to all who help answer this.
RickB.
01-14-2001 13:36:05
 Re: 1968 Ford 4000 Diesel in reply to Roger Marcus, 01-14-2001 10:00:59
If you are looking at a 3 cylinder tractor with a 2 stage clutch, it isn't a 4000. The 3 cylinder 4000's have an independent PTO clutch and wet inboard brakes. The tractor you are looking at has problems as you suspect, but it also may not be what it is represented to be. Could possibly be a 4110LCG, or a 3000.
bill
01-14-2001 11:37:24
if your pto will not work when the tractor is running the pto clutch is out and the tractor will have to be split and a new clutch put in.
