Oil and coolant mix
Art
01-28-2002 17:56:57
I recently bought a ford 2000 tractor at an auction. Runs great, but the water pump seal was leaking a little, to make a long story short, when I pulled the pump to replace it, brown gunk poured out, definitely oil / water mix. There is no contamination in the crank case. When I took the oil bath filter off, same mixture of stuff. I pulled the valve cover and every thing looks normal. How could oil enter the cooling system and not leave traces of water in the crankcase? I was considering changing the head gasket, but am now thinking someone poured oil in the cooling system. Has anyone had a simalar experiance?
Thanks for your input
Mike
01-29-2002 11:51:09
 Re: oil and coolant mix in reply to Art, 01-28-2002 17:56:57
Hey Art,
Some people think they can lubricate the water pump by putting oil in the raditor, as for the oil in the air cleaner, when you're running in a lot of humidity, like a snow storm, water tends to condense there, of course it's not a problem if you change the oil every 10 hours like the manual says.
Mike
walt
01-28-2002 21:31:48
I have a 63 2000. My oil bath gets the same results after running it. I figure its condensation from the heat mixing with the oil. I cant comment on the pump issue. A tip. If the temp is going to drop below freezing, remove the oil bath cup.. Left mine on once, froze up.
Dell (WA)
01-28-2002 20:09:00
Art..... ..My guess the brown stuff in radiator water was somesort of radiator stop-leak so he could sell the tractor with a straight face.
Do a compression check to determine if'n ya need to do the headgasket.
Be thankful the previous owner didn't put oatmeal innna radiator to seal water leaks. (ol'model T trick)..... ...Dell
