Order Ford 2000 Parts Online
Follow-up to 2000 ex-military (cdmn)
bjt
02-07-2002 09:34:04
cdmn-
S/N C447814 is consistent with a late '74 or early '75 2000 which more or less matches the production date codes you found. I'm somewhat confused in that it is supposed to be an agricultural/general purpose model and yet lacks the factory 3-point and hydraulic pump. Anyway, I'm sure you could find a way to add hydraulics and a PTO to it, but it will almost certainly require finding donor parts, including rear end castings, from another tractor. Given this and that the transmission isn't working, I'd venture a guess that this tractor is more valuable for parts than as a fixer-uper. Can you post some pictures?
bjt
