Order Ford 4000 Parts Online
3pt. lift question (72) 4000
Wayne
02-08-2002 09:52:39
Lift wont work, I'm getting no fluid at hyd pump. Can you tell me is it a straight shot from fluid reservoir (rearend), through filter to pump. I tried to bleed got nothing (no fluid) what is strange is the other day while plowing snow I looked back the arms were up, I let them down now they wont lift again. There had to be air in the system because when I removed the allen head screw at front of pump no fluid was there. I don't want to rebuild the pump for nothing. Could these symtoms be related to flow control valve or unloading valve. I Have replaced all 0-rings in lift cover and lift clyinder and piston, filters. Did not do flow or unloading valves, I kick myself for that. Any thoughts? Thanks Ahead Wayne
RWK in WI
02-08-2002 17:56:19
 Re: 3pt. lift question (72) 4000 in reply to Wayne, 02-08-2002 09:52:39
Could it be cold enough that if you had some moisture in the hyd. fluid and it froze? That has happened to me several times. Time for an fluid change.
JHILL
02-08-2002 12:54:46
How about the seal where the supply tube enters the pump. I had that problem once.
arlobenn
02-08-2002 13:14:53
 Re: Re: 3pt. lift question (72) 4000 in reply to JHILL, 02-08-2002 12:54:46
Most likely cause is the drive gear has come off the pump shaft. I've seen it happen a few times.
arlobenn
02-08-2002 13:14:52
arlobenn
02-08-2002 13:12:31
