5 Speed Trans Shifter Removal Problem
awhtx
02-08-2002 17:38:11
The starter switch on my unknown 4 cylinder diesel is loose and I want to tighten the nut on the bottom side before it falls into the gears. The manual says to remove the nut on the shifter then remove the shifter itself. I have removed the nut but I cannot get the shifter off. I have backed the nut off a couple of turns and hit it with a hammer but it still won't break loose. Any suggestions? Thanks.
RickB.
02-09-2002 10:15:12
 Re: 5 Speed Trans Shifter Removal Problem in reply to awhtx, 02-08-2002 17:38:11
I had to get one of these off the other day. I took the acorn nut off, ran a thin jam nut down just flush with the top of the threads to protect them, then used a small 3 jaw puller. The shifter sits on a keyed, tapered shaft, so if it moves at all, it will come right off.
