1700 steering box
Jim Humphrey
02-12-2002 18:46:50
I called the Ford dealer today, about the steering box on a 80 model 4wd 1700, so now I'm here looking for ways to repair or to get a replacement. It has never turned good to the left, but now I have no left turn at all, and the shaft is real loose. Any help would be appriciated.
Texadian
02-13-2002 11:12:51
 Re: 1700 steering box in reply to Jim Humphrey, 02-12-2002 18:46:50
Sounds like things have piled up inside the worm and sector box at the bottom of the steering column. The 1700 did not have a power steering option so I presume we're talking about armstrong steering. The steering gearbox is a conventional design recirculating ball nut on the steering shaft which engages with a sector gear on the pitman shaft. The sector gear is slightly tapered so you can adjust the sector shaft sideways slightly to take up for wear. There's a sector shaft adjusting screw on the right side of the gearbox. Most likely the recirculating ball nut has worn out and it's began to lose its balls. Needs to come apart and be inspected. There's a slight chance it can be cleaned up, lubricated and live for a while yet. More likely the steering shaft and ball nut assembly will have to be replaced.
