Question for Tony Jacobs.
AL
02-13-2002 20:15:13
Tony ,I have a serial number question for you.On my 4000 4 cyl. gas industrial, the serial # and model # don't quite jive.The model # is 40303 serial # 159013.There's too many numbers!On the engine block there is a casting # conn6015j, on the tranny's right side # 310835 on the rear left side # conn 4024f.I'm trying too find out the year.I'm pretty sure it's a 1962.Could you please help me determine the year.
Tony Jacobs
02-14-2002 20:27:15
 Re: Question for Tony Jacobs. in reply to AL, 02-13-2002 20:15:13
Hi Al, You have a light duty industrial 4000 that was built in the last week Feb 1962 , It has the soild non adjustable front axle but the sheetmetal looks like an ag. tractor , it is a four speed with three point and pto , they all had power steering and heavy duty clutch , and no there isn't too many numbers stamped in it , most serial number charts are not clear unless you can check a genuine Ford chart . Thanks Tony Jacobs
Paul, NH
02-14-2002 09:41:24
Hi Al, Same situation here 40303 serial 162598. I would like to know as well! Let me know if you find out. Paul
Tony Jacobs
02-14-2002 20:29:57
 Re: Re: Question for Tony Jacobs. in reply to Paul, NH, 02-14-2002 09:41:24
Hi Paul , You have about the same exact tractor except yours was built the last week of March 1962. Thanks Tony JACOBS
Al
02-14-2002 21:24:44
 Re: Re: Re: Question for Tony Jacobs. in reply to Tony Jacobs , 02-14-2002 20:29:57
Tony, thanks,i know i had to go to the right source.I even had a N.H. dealer tell me the numbers were wrong.Thanks again.
Paul, NH
02-18-2002 08:08:22
 Re: Re: Re: Re: Question for Tony Jacobs. in reply to Al, 02-14-2002 21:24:44
Thanks Tony!!
