1871 timing /starting
brian in MA
02-14-2002 18:25:17
I cant seem to get the beast to fire. I did a valve job and restored lost compression. Igot it to turn over and idle initially but would stall under throttle. I checked timing and it seemed to be off. I could not adjust by rotating dist. It seems to be 180 off but after setting to 4deg. before tdc and marking compression position and rotating dist ,it will not even fire. I am a little lost. Any suggestions would be greatly appreciated . Thanks in advance
Brian in MA
Tony Jacobs
02-14-2002 20:34:03
 Re: 1871 timing /starting in reply to brian in MA, 02-14-2002 18:25:17
Hi Brian , Where are you located in Mass. ? I am in Monson , near Palmer , Wales , Brimfield , Hampden . Email me or 1-413-267-5087 Thanks Tony
