Order Ford 601 Parts Online
12 volt converson to a 601....Dell help!
Gib
02-22-2002 10:59:28
This weekend, I will be changing my 601 to 12 volt. I am using a one wire alternator. I am not sure how to wire the idiot light so it will work on 12 volt. Any ideas?? Thanks to all that answer.
Gib
Rod MI
02-22-2002 22:46:51
 Re: 12 volt converson to a 601....Dell help! in reply to Gib, 02-22-2002 10:59:28
Gib get Tommy D. article and read it over good helped me a lot and Dell has good points to the only thing I did different whose MACK a smaller pulley sow I don’t have to rev the engine to get it to start charging and installed Dell’s Hot Roding coil the 2 inch pulley you don’t knead it and most don’t recommend it do to short belt life but I haven’t had that problem Rod MI
Tommy D.
02-22-2002 16:35:00
Gib,
See the archives. I did this exact conversion on my 1964 4000, which is a re-painted 861. It has a wire by wire description I wrote as I did it. I second the 12 volt coil too. Inexpensive, and you don't have to mess with those resistors!
Also, go to>Link
Keep your 6 volt stuff too. Your great-great grandkids may want to restore her to pull floats in the Christmas Parade (hee hee).
Good Luck!
Tommy D.
Dell (WA)
02-22-2002 13:38:06
Gib..... ...a 1-wire alternator conversion does NOT require the idiot light scheme.
While a 1-wire alternator conversion is very seductive, they're really not that great on slow turning tractor engines. Which is why I recommend the 3-wire 12 volt Delco 10SI conversion.
I also would recommend a real 12 volt ignition coil. Sometimes called "Hot-Rod" coils. Makes for a cleaner conversion by not having any 12-6 volt converting resistors to muck around with..... ..Dell
