134 as power steering fluid?
Russ (NM)
02-23-2002 20:43:47
I've got a drippy leak of power steering fluid around the steering column on my '65 3000. Can I use MC134 hydraulic oil as power steering fluid?
TimK
02-23-2002 22:11:44
 Re: 134 as power steering fluid? in reply to Russ (NM), 02-23-2002 20:43:47
Yep, definately you can use #134, that's what I use. HOWEVER ! You should not mix fluids. If you have Dexron type red fluid in it now, you should stay with it, unless you drain the whole system and then put in fresh #134. Mixing different fluids sometimes causes a chemical reaction which causes corrosion or seal wear. My $.02
Jhill
02-25-2002 07:57:54
 Re: Re: 134 as power steering fluid? in reply to TimK, 02-23-2002 22:11:44
When I put a new filter in my power steering the parts guy who I trust said do not use # 134 as it is not compatible with the seal and o-ring in the steering. He said use only power steering fluid.
RickB.
02-25-2002 17:55:41
 Re: Re: Re: 134 as power steering fluid? in reply to Jhill, 02-25-2002 07:57:54
Your parts guy is misinformed, period. 134D is currently the ONLY factory recommended fliud for use in Ford or New Holland tractors.
Above post refers to P/S systems; RickB.
02-25-2002 18:00:14
 Re: Re: Re: Re: 134 as power steering fluid? in reply to RickB., 02-25-2002 17:55:41
