Order Ford NAA Parts Online
54 NAA HYDRAULIC OIL
ANTHONY ABBOTT
02-27-2002 16:31:49
I HAVE A 54 FORD NAA TRACTOR I NEED TO KNOW
WHAT TYPE OIL TO USE IN THE HYDRAULIC SYSTEM
I WAS TOLD TO USE JUST A COMMOM HYDRAULIC OIL
IN THE REAREND,TRANSMISSION AND HYDRAULIC SYSTEM
I DONT THINK IT WOULD BE HEAVY ENOUGH FOR REAREND
OR TRANSMISSION. THEN I WAS TOLD TO RUN REGULAR
GEAR OIL IN ALL THREE.I WOULD THINK YOU SHOULD
RUN A HYDRAULIC OIL FOR THAT SYSTEM AND GEAR OIL
FOR REAREND AND TRAN. BUT IF YOU HAVE A LEAKY
SEAL BETWEEN THE REAREND AND HYDRAULIC COMPARTMENT
THEY WILL MIX . ALSO THE MOTOR CALLS FOR A 30WT OIL WOULD THEIR BE A PROBLEM TO USE 10W30 OIL
JK-NY
03-02-2002 05:34:31
 Re: 54 NAA HYDRAULIC OIL in reply to ANTHONY ABBOTT, 02-27-2002 16:31:49
I second the reommend to us FNH134 . If not getthe good (premium)universal Hyd oil fom napa I changed the hyd oi inmy NAA a couple years ago , used a Central Tractor universal hyd oil and the hyd pump would lose its prime in warm weather if the tractor sat over a couple days. Changed to the better quality oil - problem solved.
Wild Bill
02-27-2002 17:12:22
Anthony,Go to New Holland and get 134 oil for your '54 NAA. Use in hydraulic, transmission, and rear-end. I recommend 30 wt. oil in your motor unless you are in a cold climate. I also own a 1954 NAA. This is what I use and have had good luck.
Wild Bill
