Order Ford 661 Parts Online
6610 starting problem
Bob Mills
02-28-2002 20:46:25
My stepdads 6610 diesel does not spin fast enough.
Even with a new rebuild on the starter and a new
1000 amp battery, it barely grunts. Even additional jumpers from my truck does no good.
I think the starter motor is just too small for
that tractor. Any ideas?
Scott
03-01-2002 17:58:30
 Re: 6610 starting problem in reply to Bob Mills, 02-28-2002 20:46:25
If you determine it is your starter get a new one from New Holland because a rebuilt one isn't much less, part# D8NN11000CE.
Bern
03-01-2002 17:09:24
Sounds like you have a problem with excessive resistance somewhere. Possible areas include the battery cables themselves, internal contacts in the starter solenoid, and even the ground stud at the end of the starter. All of these possible problem areas can be easily checked by performing a voltage drop test at each suspect area.
TomG
03-01-2002 02:36:42
I'd start by making sure the batery cables are OK and the terminals are clean. The lower end of the ground cable often is a problem.
