Order Ford 4000 Parts Online
4000 ford exhausting oil
BRIAN
03-02-2002 21:34:03
Just need a second opinion on my problem 4000 3 cyl. since I bought it has fouled no.1 plug alot and now seems to be blowing oil out exaust even drips down side of engine pulled no.1 plug and it was covered in oil and carbon.I checked compression and it is around 140 on all three cyls. figure bad oil ring in piston on no.1.Anything else it might be before I tear it apart?Thanks
TomG
03-03-2002 03:50:09
 Re: 4000 ford exhausting oil in reply to BRIAN, 03-02-2002 21:34:03
I'd pay some attention to the valve guides as well, especially if the engine puffs smoke just as power is added. The head gasket is a candidate on some engines. Also check that the crankcase breather isn't obstructed. You didn’t mention exhaust smoke or blowby. I wouldn’t expect much blowby given the OK compression readings, but I’d expect some exhaust smoke along with the raw oil.
