Ford 445 Loader Cylinder Problem
Bob - East TN
03-03-2002 14:38:57
The bucket tilt cylinder started leaking and I purchased a pack kit from the New Holland Dealer and got 4 O rings for $55 dollars.
When disassembled I discovered the end of the tube is rusty and pitted. I surmised the rust and pits would damage the new O rings. I used 400 grit and a Dremel to polish as best I could.
I am not very impressed with the wire keeper that holds the gland nut in place. I don't think a good system. The end of the tube is exposed to dirt and water.
At any rate, I did damage the new O rings on reassembly and the sucker leaked like a sieve. Second try I doubled up the gland nut sealing rings with the old ones and used a wooden block to drive the gland home. So far no leaks, but I am very skeptical that it will hold. I see no easy way to fix. All the loader cylinders use the same keeper system, must be a Ford "exclusive". This is supposed to be an Industrial grad TLB. It is 1979 model. I hope I am not alone with this problem. I posted this same message on the Backhoe forum and didn't get any response. Maybe because I am too wordy.
Any ideas appreciated.
RickB.
03-03-2002 17:15:09
 Re: Ford 445 Loader Cylinder Problem in reply to Bob - East TN, 03-03-2002 14:38:57
That method of anchoring a gland in a cylinder barrel is not a Ford exclusive. Next time, remove ALL rust from the barrel's bore, and coat the o-ring, backup, gland O.D. and barrel I.D. with vaseline. It should pop right together. You should have gotten a new lock wire in the kit.
