Order Ford 2000 Parts Online
2000 Ford with Shuttle Trans
cdmn
03-07-2002 17:29:21
Just decided to buy the 2000 mentioned earlier. Does anyone know the speed ratios and/or ground speeds for the 4 speed shuttle transmission? If you know the ground speed, what engine rpm is that figured at? Is there a lot of rpm drop in the torque converter under load? Any special lube? Any special oil coolers? Thanks.
