Order Ford 4000 Parts Online
4000 P/S Pump options
Richard
03-15-2002 07:09:48
The current pump on my '63 4000 industrial is in need of replacement. I have found replacement pumps, but can not swing the $560. or so for a new one let alone half that. Is it possible to put an automotive/truck p/s pump on? If so, which model, mounting challenges,etc. Thanks
Rod MI
03-15-2002 10:08:49
 Re: 4000 P/S Pump options in reply to Richard, 03-15-2002 07:09:48
A auto motive pump will work I think mine is a Chevy pump out of a 78 pickup or a 77 ford pickup I would have to look this weekend repost if interested but I think any pump will work if you can make it fit good luck Rod MI
Richard
03-17-2002 08:04:23
 Re: Re: 4000 P/S Pump options in reply to Rod MI, 03-15-2002 10:08:49
Yes, I am interested in the make, model, yr and how did you come to choose that particular pump was it random or did it have the best configuration for the job with the least hassles. Also did the pump come with a pulley or did you use the original pulley. How does it perform? any low speed problems, etc. Thanks, Richard
